Reply
Bandwidth, and qos not working
PEye2000
Follower
This is my router nighthawk X10 R9000, I have latest F/W 1.0.4.12
I can not get speed test to work, pops error as to bandwidth is not reading, also tried to set it to Qos and will not load without a fail says try later..??? Running Windows 10 PC,,, any hints or help would be great... John
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
schumaku
Guru
Re: Bandwidth, and qos not working
Wrong forum, but known issue and answered several times. -> QoS Speedtest Failure on R9000 X10
Netgear offered partitioning in a Beta program for the coming-up build, the opportunity does still exist, contact @ChristineT or @Christian_R. While the measuring issue is fixed (very promptly following the related bug reports) the process seems to have stuck somehow. In any case, you can manually input the ISP contract bandwidth for the QoS config.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 843 views
  • 1 kudo
  • 2 in conversation
Announcements
