Reply
Best Nighthawk router for AT&T DSL
cgdowl7
Follower
I have AT&T DSL, and the NetGear AT&T modem/router combo keeps dropping wifi.  I just hung up with AT&T Technical support and they recommend getting a nighthawk wireless router, but they did not have a recommendation for a model.
What model Nighthawk is recommended for AT&T DSL.
Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Message 1 of 4
myersw
Master
Re: Best Nighthawk router for AT&T DSL
Just about any router should work. I personally would suggest Netgear r7800. Seems to have less firmware issues then others.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 4
antinode
Guru
> I have AT&T DSL, [...]
   Plain-old AT&T DSL, not U-verse?
> [...] and the NetGear AT&T modem/router combo keeps dropping wifi.
   Does "the NetGear AT&T modem/router combo" have a model number?  What
are the actual symptoms of "dropping wifi"?
   Do you want a modem+router, or only a router, or a separate modem and
router, or what?  Can your (unspecified) "the NetGear AT&T modem/router
combo" be configured as a modem-only?
> Just about any router should work. [...]
   Perhaps, if you have a suitable DSL modem, too.
Message 3 of 4
microchip8
Master
+1 for the R7800. Decent, solid firmware and Qualcomm-based router. It has the least issues out of most other models, like the R7000 and R8xxx series
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.87SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1441 views
  • 0 kudos
  • 4 in conversation
Announcements
