Reply
Best Settings For LBK1220 ??
Devon99
I've recently purchased a 4GX Orbi Modem
https://www.netgear.com/support/product/lbk1220.aspx
but my internet is constantly fluctuating, I'm not sure if it's the firmware, position, distance, settings, or what, but I'm having constant download speeds of 1-10 mbps but keeping a solid 35-38 mbps upload, so I'm not sure what's going on.
if anyone can help me with settings, or anything to help boost my speed, I'll give you us much detail as you need to do so.
Model: Dual Band
Message 1 of 4
Re: Best Settings For LBK1220 ??
That's a router. No modem involved.
What modem, if there is one, do you have in front of this router?
Your unnamed Internet service provider is probably the best place to ask about the best settings for its network.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
Devon99
sorry, meant Router,
I'm using Telstra 5G 400gb home//mobile broadband
the tower is 250 meters from my home, and at most carries a 700mhz 4G connection
Telstra is useless when it comes to giving advice, they just read off of prompts
so that's why I'm here
Message 3 of 4
OK. That's a different sort of Internet that means nothing to me.
Unfortunately, I doubt if there are many people here with deep experience of wireless Internet like that. It probably isn't something that Netgear has looked at in any detail.
The best bet might be to see if Telstra has a similar user group where customers share their experiences.
You aren't the first person to turn up here with that service, so, if you haven't tried it already, this might be useful:
Search - NETGEAR Communities – Telstra mobile broadband
Just another user.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 115 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
