Reply
Best antenna orientation for single story house
cavalry12
I just replaced my Linksys E4200 with the R7000 and have generally been pretty satisfied with the performance of the router. I did have one question, though. The user manual suggests pointing the two external antennae at a 45 deg angle while keeping the middle one at 90 deg (straight up).
Is this the best orientation for a single level house? I am wondering if the manual suggested orientation is a compromise for people living in mult-level dwellings and the suggested orientation may not be the best option for a single level coverage. I will do some testing with different orientations to get the best results, but wanted to get some feedback in the mean time. Thanks.
Message 1 of 2
jmizoguchi
Virtuoso
Re: Best antenna orientation for single story house
All three antenna is omni direction antenna which spread on horizontal
By putting 45Degree it helps to spread the signal evenly.
If you have not issues as is you should not need of changing it .
you can try all three 90degree wouldn't hurt or leave it is. I would use inssider and see the signal reading
http://www.metageek.net/products/inssider/
All house may result different reading
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5523 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
