Reply
Best firmware build for R8000
Danmatt
I'm trying to find the right firmware build to update to my netgear X6 R8000. Is the kong build the equivalent option, compatible to the R8000, to the tomato build that I believe is not compatible. From what I've discovered the tomato builds are the most user friendly but are only compatible with just a few routers not including my R8000. So based on this I was looking for best alternative. Any advise please.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Danmatt
Re: Best firmware build for R8000
Sorry just to clarify its a DD-WRT build for use of VPN I'm looking for?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2556 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
