Orbi WiFi 7 RBE973
Reply
Bizarre Behavior - Canon MX-850 WIRED printers not seen on network.
Hanks424
Tutor
Just upgraded an old Netgear WNDR3700 to a new R7000 Nighthawk. Everything fine EXCEPT both WIRED Canon MX-850 printers don't appear on the network. The printers work fine with the older router but neither is accessible on the R7000. The printers are ancient, but they should still show up with an IP address when hardwired to the router. Spoke at length with tech support; no joy. The router has the latest firmware. Anyone have any ideas as to what's happening??  Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
Hanks424
Tutor
Re: Bizarre Behavior - Canon MX-850 WIRED printers not seen on network.
see my second post -- problem is solved. Thanks for your input.
Message 4 of 4
All Replies
Hanks424
Tutor
NEVER MIND, after 15-20 minutes and several re-boots both printers were assigned IPs by the router. Ain't technology fun?
Message 2 of 4
antinode
Guru
> [...] The printers work fine with the older router but neither is
> accessible on the R7000. [...]
Define "[not] accessible".  Are you looking at an Attached Devices
report on the R7000, or what?  As usual, showing actual actions with
their actual results (error messages, LED indicators, ...) can be more
helpful than vague descriptions or interpretations.
> [...] The printers are ancient, but they should still show up with an
> IP address when hardwired to the router. [...]
   "show up" where/how, exactly?  LAN Ethernet port-status LED
indicators?
   What is the LAN IP address of the old router?  What is the IP address
of a printer when it's connected to the old router?  Is the printer
getting its address "automatically" (by DHCP), or did you give it a
static address?
   What's the LAN IP address of the new router?
> [...] The router has the latest firmware. [...]
   It's probably unimportant in this case, but, as always, an actual
version number would be more useful than your opinion of what's "the
latest available" today.
Message 3 of 4
Hanks424
Tutor
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 745 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
