Reply
Block Device Access to Internet D7000
Nikos2905
Follower
After upgrading from Firmware D7000_V1.0.1.52 _1.0.1. Upwards to V1.0.1.54 or V1.0.1.60, I can not set specific times for blocking Services according to Schedule. I enter the time to start blocking eg to 22 30 and stop blocking to eg 16 00 and after I press the "Apply" button the values 16 00 move automaticaly to Start blocking and the values of Stop blocking are substitude by 0 0.  This does not happen with V1.0.1.52 and the system worked perfectly well according to my input times. What am I doing wrong?
And one more question: If I do not use the "All days" option but instead choose specific days eg Mon, Tue, Wed, Thu and Fri, what will happen during Sat and Sun? Whould the blocking be completely off those day or completely on.  Thank you in advance!!!
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
Re: Block Device Access to Internet D7000
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 459 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
