Reply
Blocking device based on time schedule
LJGatlin09
Follower
How do I block internet access at specific times / schedule.  Sunday - Thursday would have different time than Friday - Saturday.  A good part of the reason for purchasing was the advanced parental controls, but those only seem to limit the level of access not completely removing access at certain times.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
storm1985
Prodigy
Re: Blocking device based on time schedule
To set a time schedule per device:
1. LAN IP reservation - so the IP wont change and blocking services always works
         (Advanced > Setup > LAN Setup)
2. Block services - where you configure the service and the IP to be filtered (if you want to completely block that device IP set Service to "ANY" or all services)
         (Advanced > Security > Block Services)
3. Schedule - the timeframe you want to set
          (Advanced > Security > Schedule)
Note: You can only set the SAME time on different days.
Message 2 of 4
Guru
which I think is the real issue here.
Message 3 of 4
storm1985
Prodigy
it is a limitation on the fw which is the same on all NETGEAR home routers either Block Services or LPC. I have some NETGEAR routers with ddwrt fw and i can also just set same time on different days or the're maybe other ddwrt but I dont need scheduling so I dont bother searching.
This is not the same as Prosafe firewall where you can set 2-3 rules with different schedules set.
Message 4 of 4
Discussion stats
  • 3 replies
  • 13218 views
  • 2 kudos
  • 3 in conversation
Announcements
