Reply
Bluetooth R9000 (Gateway)
Ra-Dzik
Apprentice
Hi,
my computer is detecting the R9000 router by Bluetooth. There are no Bluetooth settings anywhere in the router settings.
How to use this functionality? How can I use it? Is it possible to pair e.g. a Bluetooth LE beacon with the R9000 to make a smart home?
Although looking at the Netgear errors, the smart home in their execution may be a bit "crippled" ;-)
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 6
Re: Bluetooth R9000 (Gateway)
What tells you this?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 6
Ra-Dzik
Apprentice
Nothing :-( I didn't finde any documentation for this function. I can't connect through Bluetooth with router....How it's wotks?
Message 3 of 6
Yes but how do you know that your computer "is detecting the R9000 router by Bluetooth"?
That was the beginning of your first message.
Where are you looking on your computer to see this?
Just another user.
Message 4 of 6
Ra-Dzik
Apprentice
Windows -> setting -> bluetooth devices
Message 5 of 6
What tells you that this is related to the R9000?
Just another user.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 509 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
