Reply
Bricked My R8000
HuniePopPro
Bricked My R8000
So I just unbricked my R8000 last night after bricking it a couple months back (tried installing stock firmware; had DDWRT) and everything was somewhat working. With stock firmware, the wireless had no internet connection no matter what, so I installed DDWRT. After getting everything working I decided to overclock it for whatever reason. Anyway, after everything running smoothly for about an hour, I disconnect it and organize the cables and recconect it. Now it simply doesn't boot all the way. I've tried flashing through Putty via TTL to USB and SSH as well as Telnet; sadly none of those worked. I can't connect to my router through SSH/Telnet for more than a split second and when I use my TTL to USB I can't get past the CPU info. So now I'm using my old N750 with stock firmware and getting half the speed.
I haven't found a working method to get into recovery yet. I've tried the 30-30-30 method as well as several others.
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 10
Guru
Re: Bricked My R8000
Sounds like you might have wiped or corrupted the NVRAM partition. You might check with DDWRT to see if there is a way to re-seat this. If not, RMA it.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 10
@FURRYe38 wrote:
If not, RMA it.
You may have to be economical with the truth to make that work.
I doubt if the warranty would cover unauthorised meddling with the firmware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 10
Guru
True, forgot that that any warranty and support is void when 3rd party FW is installed.
Message 4 of 10
linux4088
Is there a way to restore it via serial to BusyBox cmd line? Set cpu clock default
Message 5 of 10
HuniePopPro
I'm not sure. Isn't BusyBox for Linux? If so I'm only running Windows, so I'd have to install Linux on a flash drive or something.
Message 6 of 10
linux4088
No bro Busybox is in the router via a shell. Busybox is an interesting bit in itself but you don't need to download anything... Windows, putty, and a serial cable should be all you need. Yea I didn't know it was there till I started browsing source code to compile my own firmware which you will need Linux for although all that is unnecessary..Ubuntu will work for that tho if it you chose to explore...virtual or otherwise....I know tmi
Message 7 of 10
HuniePopPro
The thing is the router wont boot all the way to the point where I can send a command through Putty. It freezes as soon as it displays the CPU info. Is there a command line I can set in Putty that automically executes as soon as the router is turned on?
Message 8 of 10
William10a
Master
You could open the router and access the serial port on the router's circuit there are videos on youtube where and how access with usb to serial connection from your computer, even how to reflash the router using the same connection.
Message 9 of 10
HuniePopPro
I already did that as I explained previously. The Putty output stops after displaying the CPU info and I can't enter any commands.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2000 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 6E
