Reply
Bugs firmware 1.0.2.40
rockscully
Tutor
Bugs in latest version:
1- Cannot update firmware to a previuous version using google chrome. After selecting file on PC and doing upload, it brings you back to windows file manager to select file again. Have to use Microsoft Edge to perform the update.
2- Does not keep the 40 Mhz bandwidth in 2,4 ghz with option "Enable 20/40 MHz Coexistence" unselected. After unchecking the option, it goes to 40 Mhz bandwidth and revert to 20 mhz after a couple of minutes though the option remains unchecked . Did not have this behavior in 1.0.2.38. I use WIFI analyzer application on android to see this bug.
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 3
JamesGL
Master
Re: Bugs firmware 1.0.2.40
Hi rockscully,
Just to check that after the update, factory reset has been done?
Message 2 of 3
JamesGL
Master
Hi rockscully,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 293 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
