- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Buying the right Mesh system to work with Nighthawk R8000P
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk router and because of house construction have deadzones - used slag from local steel works for sand in the 1920's. I think I can use a Nighthawk wifi Mesh extender in the house but have just built a garden room which will be attached to the Nighthawk via LAN. To keep the WIFI simple and smooth would like to use Mesh technology to have the coherent SSID and passwords around the whole of the property. What Netgera Mesh expetnder can I add by plugging it into the LAN/ethernet. The garden room is out of a good WiFi connection range and will be used as an office. It needs WiFi for the tech that will be in there and needs to be stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Buying the right Mesh system to work with Nighthawk R8000P
You can use the EX8000 via LAN and it has mesh.
DarrenM
