- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3000 Ooma phone service keeps disconnecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ooma customer service said the disconnecting issue is the Netgear C3000 denied ports .How can I fix this?The issue seems to have happened more in last 6 months .Have done resets but still disconnects.I've had the C3000 for a couple years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3000 Ooma phone service keeps disconnecting
do any other devices have issues?
What actual problem are you running into?
How did they determine it was the router causing the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi plemans,Just have Ooma and a laptop connected to the C3000.No issues with laptop .Comcast is service provider.Ooma had me run a diagnostic report and it showed about 30 denied ports and I was told to contact Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
some ooma's have an their own integrated dhcp server.
Have you tried putting the ooma's IP address into the netgears DMZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your solution is probably beyond my computer skills. I had to look up dhcp and DMZ..Do I need to download the Nighthawk app to add The Ooma address?Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
its fairly simple to do. you can do it through the browser.
Here's the guilde.
How do I set up a default DMZ server on my NETGEAR router? | Answer | NETGEAR Support
