Reply
C7000-ethernet works but no wireless
aLOTRlover
Follower
Have done all the troubleshooting with cable company. No go.
I made no recent changes to router..
The NG website says for troubleshooting to connect through device that is connected to wireless router, but the router is giving no signal. Have only phone with LTE to reset this router. How can I make wireless work again?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: C7000-ethernet works but no wireless
Did you push and hold for 2 seconds the wifi on/off button?
C7000V2 | Product | Support | NETGEAR
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 153 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
