Alex72055's avatar
Alex72055
C7000v2 no internet
My isp has told me it’s the device randomly the internet dropped and never came back
Right now the off lights are : downstream and the internet globe I have done multiple resets
Net gear could only help if I paid for service
  • plemans's avatar
    Move the modem to right where the coax enters the home, remove any splitters, amplifiers, splitters from the line.
    Again, direct connect it.
    the modem has to establish a link to the ISP and from the lights, it isn't doing so.
    also, log into the router and get a screen snip of the cable connections page and the event logs and post them back here. they let us check the connection back to the isp.
      • plemans's avatar
        The "event log"
        and the cable connections page, it shows upstream/downstream power levels, errors, etc
    • Alex72055's avatar
      Alex72055
      My ISP which is Cox is saying they are getting no connection to the modem
