Reply
C7000v2 not reaching full download/upload speed
CJ_Does
Follower
Recently upgraded my internet speed through my provider. I should be getting 300mbps down over wireless but only get it over Ethernet.
I get around 150 via wireless. Any suggestions on how to speed the wireless up without doing a reset?
I have too many devices connected to my network and it would take me a day to set everything back up if I did a factory reset.
Message 1 of 3
Guru
Re: C7000v2 not reaching full download/upload speed
a couple things.
1. wireless isn't as fast as wired.
2. 2.4ghz is a slow network. ensure your testing over 5ghz. its still not going to be as fast as wired but it'll be faster than 2.4ghz
3. what device are you testing on? a 1x1 client is going to have half the speed of a 2x2 client
4. how far from the router is the device you're testing on? and whats in between the 2?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
You do not need to change anything on your wifi clients if you give the C7000v2 the same SSIDs and passwords as it had before the reset.
As @plemans suggests, that's not bad for many wifi clients. Put it another way, your router can deliver wifi at a gazillion miles an hour but wifi clients stuck in the slow lane will still crawl at a snail's pace.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 121 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
