instgtr75
Jan 22, 2021Follower
C7800-200NAS Nighthawk Dual-Band AC3200 Router with 32 x 8 DOCSIS 3.1 Cable Modem
i am trying to find the qos to make game primary and wheni log in and can not find tab for qos anywhere
Your subject says " C7800-200NAS Nighthawk Dual-Band AC3200 Router with 32 x 8 DOCSIS 3.1 Cable Modem". Does that mean you are using the C7800 modem/router connected to a separate modem?
What does that mean?
I see no reference to QoS in the manual for the C7800. What makes you think that the modem/router supports it?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers - plemansGuru - Experienced User
The C7800 doesn't have QoS.
