Reply
CAX80 Best Settings for Fast Speed
gregcowell
Can someone guide me in the advance settings on the best way to get better speed. I replaced with my Xfinity router and am getting slower speeds
Message 1 of 14
Guru
Re: CAX80 Best Settings for Fast Speed
What speeds are you getting?
and are you slowed speeds over wired or wireless?
What speeds do you pay for?
Which version of firmware are you running on the router side?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 14
gregcowell
What speeds are you getting? 120mbps
and are you slowed speeds over wired or wireless? Wireless
What speeds do you pay for? 1gig
Which version of firmware are you running on the router side? The most up to date it says
Message 3 of 14
Guru
what speeds are you getting hardwired in? that's the key.
And when youo're testing wireless, are you testing using smart connect? aka it could be running over the 2.4ghz. Which is a lot slower than 5ghz.
Message 4 of 14
gregcowell
Hard wire I am at 600+ I don’t have smart connect on... 2.4 I am getting 40mbps
Message 5 of 14
Guru
Do you have a screen snip of your cable connections page?
If you're paying for 1 gig, you should easily be able to get that with the CAX80.
In terms of wireless, a lot depends on what device your using. A 1x1 antenna setup isn't going to get the same as a 2x2 setup. Or even if you're using a wireless N dual band device versus a wireless AC device. or if you're using 160hz wide channels and the device you're on isn't capable of them.
So what device are you testing on?
Driver on that device?
Firmware on the router side of it?
Message 6 of 14
gregcowell
So what device are you testing on? iPhone 11 Pro Max and 2019 Mac Book Pro
Driver on that device? Don’t know
Firmware on the router side of it? V1.1.0.41
Message 7 of 14
gregcowell
Message 8 of 14
gregcowell
Message 9 of 14
Guru
You missed more than half your downstream channels and the other details such as uncorrectables.
If you have any splitters, attenuators, or amplifiers in line, I'd recommend removing them.
try changing the wifi on the 5ghz to a higher band channel. As far as I know the iphone 11 doesn't have 160hz wide channels.
Also, what website are you using for testing?
Message 10 of 14
gregcowell
I only have 1 splitter and it’s the one coming from the outside. Nothing else attached to it. and I am using Speedtest
Message 11 of 14
Guru
speedtest doesn't always saturate gigabit as sometimes it selects test servers without those capabilities.
try dslreports, fast.com, or speedtest.xfinity.com
Is it only apply devices with issues? have you tried any windows or android devices?
Message 12 of 14
gregcowell
44 on 2.4 and 500 on 5ghz now... that was through fast.com
Any settings I can change for the 2.4?
Message 13 of 14
Guru
2.4ghz is significantly slower than 5ghz and is more sensitive to interference. Its was the main reason for moving to 5ghz dual band routers.
You can try changing the wireless channel the 2.4ghz is on to a less congested channel. Or upgrading your wireless to chip to AX if you need a little more speed out of it.
On my orbi system, I usually hit around 30mbps average (peaks of 70mbps).
On my RAX200 syste, I can hit average of around 60mbps with peaks >100mbps. But again, those are peaks. its average speed is much lower.
2.4ghz is just that slow.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2255 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
