- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM400 NETWORK SECURITY KEY
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Setting up a new laptop and it auto-detected Netgear 05 and it is asking for the network security key. No idea! Suggestion??
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM400 NETWORK SECURITY KEY
> Setting up a new laptop and it auto-detected Netgear 05 [...]
"NETGEAR05"?
> [...] and it is asking for the network security key. No idea! [...]
Look at the product label?
> [...] Suggestion??
First: Find your wireless router.
> Model: CM400|DOCSIS 3.0 Cable Modem
Is that device new, too?
The CM400 is a _modem_, not a wireless router. Follow the Ethernet
cable from the CM400 to your wireless router. If it's not connected,
then you might need to expand your search.
When you find your wireless router, look on its label for "Model".
With _its_ model number in hand, you can take the next step:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read.
If "NETGEAR05" belongs to your neighbor, and you have only the CM400,
then you probably want a router.
