Orbi WiFi 7 RBE973
Reply
CM700 and R7000 Mediacom issues
doug14
Follower
I've been running 100Mbs 1000G/month through Mediacom for 2 years and have had several slow speed incidents and devices randomly disconnecting/reconnecitng over the past week. Netgear won't help since my devices are 2 years old. I called Mediacom and they said my CPE IP address that starts with 150. is not compatible with the ones they run starting with 50., 104., 108., and 173. They sent a technician out anyway and he replaced a male to male connection fitting that he said caused "noise" but after he left, my problem remains - intermittant connection issues. Sorry this is so broad, but where do I go from here?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: CM700 and R7000 Mediacom issues
Are you able to check the logs in the CM700 and look for any T3 or T4 timeouts happening. If so this would indicate a bad connection with the ISP.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 303 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
