Reply
Cable Modem speed restrictions
RICHARD281
The box for CM1000 cable modem has - Only DOCSIS 3.1 modem enable 1 GBPS cable internet service.
I have a dumb question. If my Comcast internet speed plan is over 1 gbps will this modem cap my speed at 1 gbps?
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 3
Accepted Solutions
Guru
Re: Cable Modem speed restrictions
yes. Its ethernet port is only rated to 1gig so you'll max out with 1 gig.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
All Replies
Guru
Message 2 of 3
RICHARD281
Thank you, I decided to go with the CM2000 modem.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 184 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
