Reply
Can I combine two AC2200
ChasGre
Follower
I have two of these ORBI systems:
RBK43-200NAS           (RBR40 Router, 2 x RBS20 Satellite)
I am hoping to take the two satellites from one of them and add them to the other system so I end up with one RBR40 Router that has 4 x RBS20 Satellites. Is this possible and how would I reprogram the two satellites that are moving to the new RBR40 Router? The other router would then no longer be used.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: Can I combine two AC2200
Yes you can add the other satellites to the current system.
https://kb.netgear.com/000053867/How-do-I-connect-a-satellite-to-my-Orbi-router
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 173 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
