Reply
Can I connect my cable modem C6250
Seoart
Can I connect my cable modem C6250 to the app Nighthawk?
Model: C6250|AC1600 WiFi Cable Modem Router
Message 1 of 6
Guru
Re: Can I connect my cable modem C6250
Looks like the C6250 is still using the genie app.
https://www.netgear.com/support/product/c6250#docs
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 6
Seoart
I read it. But the app did see a router.
Another problem that router every time reloads and didn’t give IP for my 5 devices. And 2.4 antenna is switched off and reloaded every time too.
Message 3 of 6
Guru
Is this a new device?
Who's your isp?
do any devices work on it?
Message 4 of 6
Seoart
It’s not new. I use it a 2 year.
Message 5 of 6
Seoart
For me, it’s like a conflict between two antennas and IPs.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 153 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
