Reply
Can I disable 802.11b in R7000P?
Netmammal
I discovered today that my router is advertising availability to the old 802.11b wifi version/protocol, which I've alway understood would lower the performance of the more recent wifi versions/protocols if it were enabled. I can not find a place in the management screens to control which wifi  versions are enabled for my router?
If I am mistaken, and leaving 802.11b enabled is OK, that would be good to know as well.
Thanks,
-Dave
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 5
Netmammal
This is for an R7000P... thought this forum would post that.
Message 2 of 5
myersw
Master
Re: This is for an R7000P... thought this forum would post that.
Only time this might come into play is if you had a very old device that only speaks 'b'. As long as no 'b' devices there should not be a problem.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 5
Netmammal
That was my understanding of 'b' as well, but also knowing how common it is for multiple implementations of protocol negotiation stumble, I would prefer to control the issue, instead of leaving it up to some stupid device and the router to decide for me. I guess I'm used to the open source firmware I was using previously where you can control (sometimes) too much.
If one of the many wireless devices in my house somehow negotiated to use 'b' on my router, how would I know? How would I know which device was the troublemaker, even if I did somehow know that the router had fallen back to using 'b'. I know that I have gotten rid of the last 'b'-only device like 3-4 years ago, but that does not mean that I can really be sure that I have left 'b' behind.
It just occurred to me that this is a way to hack somebodies wifi network without even having the wifi key. Connect a 'b'-only device, even if you fail to log in, you've probably forced their network to slow down to 'b' until the then next when? Reboot? 24 hours? who knows!
Message 4 of 5
myersw
Master
Some of the newer routers seem to be able to sort things out and not penalize the rest of the connections. Back when G first came out, yes a B device would cause the whole connection to drop back.
--Bill
Tesla > Edison
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1019 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
