Reply
Can I enable telnet on my R8000?
MrGreenjeans
Follower
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 6
microchip8
Master
Re: Can I enable telnet on my R8000?
Usually there's an option at http://192.168.1.1/debug.htm
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 6
@MrGreenjeans
Check @microchip8's suggestion and let us know.  There is no option on my model, 8000P with 1.1.4.24, but yours might be completely different.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 3 of 6
myersw
Master
Not on my r8000. Just checked. Running v1.0.4.18_10.1.49 firmware. Used to have to run a program that would enable as I recall. I just brought this out of the closet, loaded latest and running as AP. I remember enabling Telnet a year or so ago using an app. Sorry I do not remember, but suspect Google will find it.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 4 of 6
antinode
Guru
> Usually there's an option [...]
   "Usually"?  You surveyed all the devices and firmware versions?
   A Web search should find various "Netgear Telnet Enable" programs,
which can enable a Telnet server on many Netgear routers.  (I use this:
http://antinode.info/nte )
Message 5 of 6
myersw
Master
Thanks for posting. That was the program I was thinking about for enabling telnet on r8000.
--Bill
Tesla > Edison
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3210 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 6E
