Reply
Can I extend guest access on a dst6501 extender?
grayclarke
Follower
Message 1 of 2
Retired_Member
Not applicable
Re: Can I extend guest access on a dst6501 extender?
A guest SSID is no different than a none guest SSID so it should work. It might have some impact on the main SSID since they use same radio and channel.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1374 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
