Reply
Can I force 5G for a device when Smart Connect is enabled?
emanon
Tutor
On a R7000 is there a way to always force a device to connect to the router using 5G when Smart Connect is enabled?  I don't want to broadcast both 2.4G and 5G but my printer does not support 5G. Therefore Smart connect works best to avoid broadcasting both.  However, my TV set top box always connects with 2.4G when I prefer 5G.  I am 100% sure that my set top supports 5G.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
JamesGL
Master
Re: Can I force 5G for a device when Smart Connect is enabled?
Hi emanon,
When smart connect is enabled, it automatically connects to the either of the band. There is no way to connect it manually to a specific band.
Message 2 of 3
emanon
Tutor
Ok thanks for the reply.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3519 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
