Reply
Can I use My R7000 backed up configuration settings file on my Nighthawk router R8000?
ZULU747
Dear All: Upgrade from R7000 to R8000, Can I use My R7000 backed up configuration settings file on my Nighthawk router R8000?
Thanks your Reply
Message 1 of 4
Accepted Solutions
netwrks
Master
Re: Can I use My R7000 backed up configuration settings file on my Nighthawk router R8000?
Config is not portable between routers (7000 to 8000).. Best to copy / paste  config into a doc, or, do screen grabs of the info you need / want from the 7000.
Message 2 of 4
All Replies
netwrks
Master
Message 2 of 4
ZULU747
Thanks for your Quick answer!
Message 3 of 4
JamesGL
Master
Hi @ZULU747,
Welcome to Community!
@netwrks is correct. The config file of R7000 is for R7000 only and cannot be loaded on different models. The router will not accept it as it will be detected that it is for a different model.
JamesGL
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2461 views
  • 1 kudo
  • 3 in conversation
Announcements
