Reply
Can a Nighthawk X6S (R7900P) tether to a jetpack via usb?
brang97603
Hello all.
I would like to tether a Verizon Jetpack (7730L) to the Nighthawk X6S (R7900P) for LTE internet access. Can this be done? If so, how?  If not, is there anything available (via Verizon) that can allow the X6S to connect to LTE?
Thanks for your help
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
Re: Can a Nighthawk X6S (R7900P) tether to a jetpack via usb?
The only thing that connects to a router via USB is storage. Even then, there are some devices that won't work.
As for the rest, I have no idea what a  Verizon Jetpack (7730L) does.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
brang97603
OK Thanks for the info. In regards to the USB port, that is what I was afraid of. That particular jetpack has only a USB out.
Does anyone have any recommendations on something I can use to connect to Verizon LTE as the internet source. I found the Netgear LB2120 but it appears to only work on AT&T. This little guy would work well for my application if it were Verizon.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1025 views
  • 0 kudos
  • 2 in conversation
Announcements
