Reply
Can access wi-fi network but internet does not work
jpnstp
Follower
I am able to plug directly to the modem and confirmed that Internet is working fine from my ISP.  When i plug the modem to the router, it does not recognize the internet.  I have power cycled, done a hard reset to factory settings and can not thing of anything else to try.  The router itself works fine.  I have been able to connect to it in the past and all my wireless devices are able to find the network just fine.
firmware: 1.0.2.62
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Can access wi-fi network but internet does not work
What modem do you have and what ISP? Does the modem have a built in router? if so have you tried to disable the router or put it in bridge mode before connecting it to the Netgear router?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 352 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
