Reply
Can not add domain in security settings
Gendos
Initiate
Hi!
Firmware version V1.0.4.12_10.1.46
In the admin panel: Advanced -> Security -> Block Sites in text field i add site domain swich i want to block. I add the domain and press Apply, than I receive message "400 Bad Request
This server does not support the operation requested by your client."
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
antinode
Guru
Re: Can not add domain in security settings
> [...] "400 Bad Request
   Sounds like typically bad Netgear firmware.  You could try resetting,
and manually reconfiguring, the thing.  You might get lucky.
   Otherwise, you could try older firmware versions, to try to determine
when the problem first appeared.  Then complain to Netgear?
   A quick Web search (netgear r8000 "400 bad request") found, among
many other things, this similar report (with a similar response):
      https://community.netgear.com/t5/x/x/m-p/1507790
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 519 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
