Orbi WiFi 7 RBE973
Reply
Can not connect to other machines on network with R9000
Boulda
Tutor
I have just installed the R9000 last night.
I am not having issues connecting to other PC / network shares.
All the machines can get out to the internet. I can connect to them via remote desktop.
However I can not ping any of the machines, and I can not connect to any of the network shares between the machines.
Have I overlooked some setting in the Router?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Accepted Solutions
TheEther
Guru
Re: Can not connect to other machines on network with R9000
When changing routers, Windows will often think that it has connected to a new network and will proactively treat it as a public network.  On Windows 10, you will have to change the setting to make the PC discoverable.
Message 2 of 3
All Replies
TheEther
Guru
Message 2 of 3
Boulda
Tutor
That was it thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3109 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
