- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can not get Nighthawk R7000 to allow my Iris by Lowes hub to connect, plaese help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just tried to install my Iris by Lowes gen 2 hub. I can not get it to register with Iris app or with Iris phone support. I have a netgear nighthawk R7000, have it wired in and I went in and set port forwarding for ports 80,443 and I "think" I did it correctly. I have reset everything multiple times and the hub just goes to flashing green (which means it is just waiting to be connected) and the app will not find it when I try and add the hub. Phone techs said to let it sit a day and call back but it has been sitting with no change so I figured I would post on here to see if anyone may have more insight
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi EricZZ,
Did the hub works with different router? Or is this the first time configuring the hub?
Do you have other devices that works with the router?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi EricZZ,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can not get Nighthawk R7000 to allow my Iris by Lowes hub to connect, plaese help!
Hi EricZZ,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
