Reply
Can't Login to Netgear Router after Firmware Update
DEROS
Tutor
Just update my Nighthawk X6 with the most current firmware.  However, routerlogin.net no longer works.  Circle keeps on poping up instead of the log in screen.  I tired using the ip address instead and I get an error saying the ip refused connection.  How do I get access to the router configuration?
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
xnsys
Luminary
Re: Can't Login to Netgear Router after Firmware Update
Does eveything else work?
If so - have you tried power cycling it?
If that doesn't help - may need a factory reset.
Message 2 of 3
DEROS
Tutor
I guess it was a failed firmware update.  After I power cycled the router, I was able to get back into the router.  The message about having a new firmware was avaiable was still there.  I went ahead and downloaded and install.  This time firmware upgraded was completed and the router is working.  Still have to test the VPN, which is why I needed the firmware update.
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2424 views
  • 0 kudos
  • 2 in conversation
Announcements
