- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Can't Login to Nighthawk "Your Connection to this site is not private"
Getting this error in Chrome with McAfee safe browser turned off. Will not let me login at all- I can't ignore the warning like suggested in other posts. It will not log me in after 50 trys.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Can't Login to Nighthawk "Your Connection to this site is not private"
What route are you using?
What modem are you using?
What firmware are you on for the router?
you didnt' give us much to go off. More details help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
> [...] Nighthawk [...]
Which? Model number? Look at the product label.
Try a different browser?
> [...] I can't ignore the warning like suggested in other posts. [...]
You need to. If your (unspecified) "Nighthawk" offers only "http://"
access, not "https://", then you need to use a web browser which will
allow that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Tried a different browser?
They are getting more and more picky about web and happily block you from getting at safe links.
How are you trying to login? IP Address?
Wired connection? Wifi?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for all the replies. I finally found the model number by downloading the Netgear Genie. Then I saw the model number in very tiny print on the router. I don't know why they make serial number and other info so large and the model number so small. I could not see it at all before.
I was able to fix the issue by downlaoding the Genie, reseting the router by inserting paperclip and using admin and password as login credentials. I then reset my password to the original and all is fine. I tried Edge browser and it seems to have less security, I did not get the same error. I guess it is possible I was using the wrong password, but that is not the message I got with Chrome or Edge.
Thanks!!
User | Count |
37 | |
18 | |
8 | |
5 | |
5 |
