Reply
Can't Remote into Nighthawk R8000P router
nie1aal
Follower
I routinely login to the router from within the network, but when trying to access remotely via Genie, I get the error message "Login Failed Enter the correct admin user name and password for your NETGEAR router."  I am entering the correct username and password.  This problem is recent.  I was successful logging in remotely prior to the last firmware update.  Recommendations?
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 2
myersw
Master
Re: Can't Remote into Nighthawk R8000P router
Since r8000p firmware is known to be buggie, if you install what worked before do things work then? If so I would leave well enough alone and wait for next update.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 347 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
