- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't access admin page for C7800
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can only access the admin page (192.168.0.1) after I reboot the router.
How do I access the admin page without rebooting the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't access admin page for C7800
have you tried going to 192.168.100.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yea I've tried 192.168.0.1, 192.168.0.1.1, and 192.168.100.1
The address that consistently works after reboot is 192.168.0.1 and it is also indicated as the "router" in the network preferences.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a simple factory reset and reinstall?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I've tried the factory reset and re-registering with the ISP (the ISP controls the firmware so can't do a proper reinstall)
- Mark as New
- Bookmark
- Subscribe
- Permalink
everything else works?
have you tried other browsers or pc/laptops?
what error do you get?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've attached an example of the type of error from the IPv6 test. So right now IPv4 sites don't work.
I've tried Chrome, Safari, and Firefox. I've tried on 2 laptops and 2 iPhones.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure why you think the ipv4/6 is causing you to think this is why you can't access it.
What error do you get when you try to access the admin portal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah sorry. I was responding to the wrong ticket.
I've attached the error I get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And you've tried a different pc?
Are you hardwired into the C7800?
You tried the 192.168.100.1 when hardwired in?
And tried different browsers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I've tried on 2 laptops.
I just tried 192.168.100.1 on Firefox and Chrome via ethernet connection directly to the router. Same result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you ping it?
Is there anything else connected to the router?
Like a managed switch, another router, access point, etc.
Just connect the 1 device after the reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the ping log:
ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1): 56 data bytes
64 bytes from 192.168.0.1: icmp_seq=0 ttl=64 time=4.752 ms
64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=4.589 ms
64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=5.477 ms
64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=3.989 ms
64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=4.527 ms
64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=5.114 ms
64 bytes from 192.168.0.1: icmp_seq=6 ttl=64 time=4.748 ms
64 bytes from 192.168.0.1: icmp_seq=7 ttl=64 time=4.414 ms
64 bytes from 192.168.0.1: icmp_seq=8 ttl=64 time=4.799 ms
64 bytes from 192.168.0.1: icmp_seq=9 ttl=64 time=4.732 ms
64 bytes from 192.168.0.1: icmp_seq=10 ttl=64 time=5.610 ms
64 bytes from 192.168.0.1: icmp_seq=11 ttl=64 time=4.715 ms
No switches, routers, or AP.
I'll try restarting with only 1 device now.
