Orbi WiFi 7 RBE973
Reply
Can’t connect to plw1000 extender
Jillys75
Initiate
Hi my extender worked for ages and has Just stopped working - only noticed when phone data allowance was exhausted. Trying to reset : fix. My WiFi devices cannot see the extender which used to have 5G in name. I’ve tried pressing wps on router then extender to pair but blue light on extender just keeps flashing. I am useless with IT. Can anyone help? Thanks
Model: PLW1000|PowerLINE 1000 Wireless adapter
Message 1 of 3
Guru
Re: Can’t connect to plw1000 extender
Have you tried factory resetting it and just reinstalling it (not using wps)?
there's the install guide that does over installing it.
PLW1000 | Product | Support | NETGEAR
Message 2 of 3
Jillys75
Initiate
Thank you I’ll try that now
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 360 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
