Reply
Can't connect to wifi
Addiechick
Follower
My internet provider had issues so didn't have internet for days.  They came to fix it and now I can't get the netgear wifi to work.  The internet button is lit up but can't connect.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 2
antinode
Guru
Re: Can't connect to wifi
> [...] I can't get the netgear wifi to work.  The internet button is
   "can't connect" to the router using a wireless device?  What,
exactly, did you do?  What, exactly, happened when you did it?
   What do the other LED indicators on the router indicate?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Table 1. LED
Descriptions".  Did you press the "WiFi On/Off button with LED"?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 190 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
