- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't disable remote access to web interface of Netgear r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I type my external ip addess, I can access Netgear's web interface.
If i go to Advanced -> Advanced Setup -> Remote management , I have "Turn Remote Management On" unticked.
Is there a way to diable external network access to the web interface?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> If I type my external ip addess, [...]
Where?
https://community.netgear.com/t5/x/x/m-p/1671127
> Is there a way [...]
Yes, and (you say that) you've done it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't disable remote access to web interface of Netgear r7000
@Petrakeas wrote:If i go to Advanced -> Advanced Setup -> Remote management , I have "Turn Remote Management On" unticked.
This should be sufficient to disallow the access to the Web UI on the Internet/WAN Interface.
Router is operating in router mode, connected to the Internet with the Internet/WAN port and is not located somewhere behind a different router and some port forwarding does grant the access to the LAN interface?
What firmware version are we facing here?
Done a factory reset?
If true, this reads like yet another brilliant Netgear "feature" implementation, and lack of firmware PQA @Christian_R
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was my bad after all because I was testing this from withing my network. If I try to connect from my phone using cellular data, I can't connect.
As explained here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/How-to-disable-WAN-login-on-R7000/m-p/167112...
"If you're testing from inside your LAN, then the "NAT loopback"
feature of the R7000 could make it appear that a request to the
WAN/Internet IP address of the R7000 will get a response, but the result
from the outside world could be quite different."
