Reply
Can't enable 5 ghz wifi
C337Skymaster
Follower
I found the forum post about using the wifi on/off button on the Netgear Nighthawk (which is not even REMOTELY obviously a button, by the way), but when I used it to solve my problem of the yellow "Wireless Off" status on routerlogin.net, it only enabled the 2.4 Ghz band. the 5 ghz band is still off, and in the Advanced section, it shows "Wireless AP: Off" under the 5 ghz band. How do I turn this back on again? I've tried pushing the two buttons on the router in all three combinations to no avail. The wireless button functions as an on/off for the 2.4 Ghz band only, and the 5 ghz band remains stubbornly disabled.
Thanks for any insight you might have!
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
William10a
Master
Re: Can't enable 5 ghz wifi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2181 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
