stivi_01's avatar
stivi_01
Can't factory reset my Nighthawk X8
Good morning all,
our Netgear R8300 suddenly stopped working while I was not at home a couple of weeks ago. I managed to set my wife up with a backup router.
Now that I am home I was trying to perform a factory reset first which doesn't seem to do anything.
When performing the factory reset nothing is happening until 13 seconds, then it will light up port LEDs 1 2 and 3 briefly then follows with the rest.
after 1 minute or so the only LEDs I see are the power LED being red (orange) and the port I am plugged into the Router in white (currently port 3)
No other LEDs are on. After another 2 minutes or so it will again flash all the lights and then also leave the Guest WiFi LED on in white.
And this is the current state.
The Router doesn't give an IP Address, when assigning a static IP in the default 192.x range it doesn't respond to pings on the default IP (which was never changed).
I am not sure at this stage if there is anything else that can be done with this device? It was purchased in 2018 already so no warranty any more unfortunately.
Any other suggestions are welcome.
Thank you,
Stefan
    • stivi_01's avatar
      stivi_01
      Sorry for my late replay but a huge thanks to you. I was looking for something like that but couldn't find it in the kb myself.
      this indeed worked. The router feels a bit sluggish but it should survive the next two weeks until I will replace it with a Ubqiuiti router anyways :)
      thanks again for your help.
