Reply
Can't install firmware 1.0.9.42 on R700P
mattrogers13
I performed a factory reset on my router using both the software method and the paperclip method. Then manually installed the firmware V1.0.9.42_10.2.44. But the firmware # won't change from V1.3.1.64_10.1.36.
I've been haivng issues with the 5g wireless channel dropping at some recomendations here on the forums suggested going back to 1.0.9.42.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: Can't install firmware 1.0.9.42 on R7000P
> R7000-V1.0.9.42_10.2.44.chk
      "R7000".  So, _not_ for an "R7000P".
   Visit http://netgear.com/support , put in _your_ model number, and
look for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.  (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
Failing a helpful User Manual:
      https://kb.netgear.com/23960
   If it's any consolation:
      https://community.netgear.com/t5/x/x/m-p/1988409#M170426
Message 4 of 5
All Replies
antinode
Guru
Re: Can't install firmware 1.0.9.42 on R700P
> [...] some recomendations here on the forums [...]
   Thanks for the helpful links.
> [...] suggested going back to 1.0.9.42.
   On what?  "R7000" and "R7000P" are spelled differently for a reason.
> [...] manually installed the firmware V1.0.9.42_10.2.44. [...]
   What was the whole name of the relevant file?  Did "R7000P" appear in
it anyplace?
Message 2 of 5
mattrogers13
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-dropping-5Ghz-randomly/td-p/1898930
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-5g-keeps-losing-internet-2-4-unaffecte...
R7000
it anyplace?
Message 3 of 5
antinode
Guru
Message 4 of 5
mattrogers13
Thanks, I realized the issue from your original responce.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1353 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
