HansVanMeurs's avatar
HansVanMeurs
Can't login to my Nighthawk when it's in bridge mode
I've setup my R7000 in bridgemode. It now picks up my mobile hotspot fromml my cellphone and enables internet to my wired supplies correctly.
But since I've switched it in bridge mode I am not able to login (as administrator) to my R7000 anymore. I use a wired connection of course.
Is anyone familiar to this issue, and how do I solve the problem?
  • > [...] since I've switched it in bridge mode I am not able to login (as
    > administrator) to my R7000 anymore. [...]
       "not able" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] I use a wired connection of course.
       And some URL or other in a web browser?
       In a non-router mode (wireless access point or bridge), a router like
    this will get a new/different LAN IP address, and may or may not be able
    to intercept a "routerlogin" name, so you'd need to determine its
    new/different LAN IP address, and use that in your web browser.
       Presumably, the router-as-bridge got its new/different LAN IP address
    from (the DHCP server in) your main router ("my mobile hotspot fromml my
    cellphone", so I'd look there for some kind of "Attached Devices" or
    "DHCP Clients" report which would reveal that address.
    • HansVanMeurs's avatar
      HansVanMeurs
      Thanks for your reply.
           I tried to login using a wire between my laptop (OS windows 10) and the R7000 (slot 1 of 4). I started my Firefox browser and tried to get the administrator login "http://www.routerlogin.net". But I didn't get any connection at all, neither using "http(s)://www.routerlogin.com", "192.168.0.1", nor "192.168.1.1".
           As said before I use my Android cellphone (Samsung S20 Ultra 5G) as a mobile hotspot for my R7000 to login to. By the way: that gives a working Internet access to my laptop and other wired devices for browsing the Internet. But not for getting access to my R7000's settings, being the problem we are discussing right now.
      Your analysis look very accurate:
           'Presumably, the router-as-bridge got its new/different LAN IP address from (the DHCP server in) your main router ("my mobile hotspot from my
      cellphone")'
           This might be the very problem: at setting the R7000 as bridge I got a (general?) warning from my R7000 saying "Change the IP-address of your computer manually, in case the LAN-IP subnet is changed". But IS it changed? How do I detect that?
      Presuming this causes the problem indeed, you suggest:
           '...so I'd look there for some kind of "Attached Devices" or "DHCP Clients" report which would reveal that address'.
            I don't know how and where to find these settings: on my laptop? On my hotspot cellphone? On both?
      And into what values should I change the LAN-IP subnet?
           I used the windows help, and my android's help, but couldn't get any valid help entry by the words "DHCP" nor "LAN-IP subnet".
      • antinode's avatar
        antinode
        Guru
           I'd look at your (unspecified) "my hotspot cellphone", about which I
        know nothing.  It is what is acting as the wireless router.
           I wouldn't change anything; just try to learn the address of the
        router-as-bridge.  (I never mentioned "subnet".)
        > [...] my android's help [...]
           I know nothing, but I'd try a Web search for terms like, say:
              android hotspot connected devices
