Reply
Can't register my R7000
bsnuggs
I can't register my router.  I try on the support web page and it says:  "Something went wrong, Please contact support team."
I try with Genie and it says: "Resource Validation Error".
Any ideas?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Re: Can't register my R7000
That's not the usual error, but the solution may be the same.
You have a couple of options, try to find a local contact number (it may be well hidden) or send a private message to one of the Netgear moderators here.
If you are really lucky, someone like @DarrenM or @ChristineT will take pity on you and step in.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
bsnuggs
Replaced the router (for other reasons...it was time).  Not a problem anymore.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 332 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
