Reply
Can't stop responding to outside pings
HardKnocks
R6900 - Firmware Version V1.0.1.46_10.0.29
My configuration is set to deny responses to outside pings (checkbox unchecked) but when I run Gibson Research Shields Up or any outside web ping, they show that my router is responding to pings. I have reset the router to factory settings and reloaded, rebooted the ISP DSL modem and Nighthawk router but nothing stops the responses to pings.
Help! I'm exposed.
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 5
Blanca_O
NETGEAR Moderator
Re: Can't stop responding to outside pings
Hi HardKnocks,
A new firmware update is available. Please update the firmware to 1.0.1.48.
https://kb.netgear.com/000059129/R6900-Firmware-Version-1-0-1-48
Blanca
Community Team
Message 2 of 5
antinode
Guru
> [...] they show that my router is responding to pings. [...]
   _Something_ may be.  Who decided that it's the R6900?
> [...] rebooted the ISP DSL modem [...]
   What is your "the ISP DSL modem"?  Is _it_ responding?  Did you try
disconnecting the R6900?
Message 3 of 5
Blanca_O
NETGEAR Moderator
Hi HardKnocks,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 4 of 5
HardKnocks
It’s my ISP that is responding with their DSL modem. Not Netgear. Thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 252 views
  • 0 kudos
  • 3 in conversation
Announcements
