Reply
Cannot connect to VPN on R8500 using OpenVPN
DOTCOM79
Follower
I am using the default settings:
client
dev tap
proto udp
sndbuf 393216
rcvbuf 393216
push "sndbuf 393216"
push "rcvbuf 393216"
dev-node NETGEAR-VPN
remote <URL> 12974                *URL removed for security
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 0
I am trying to connect directly to the router to remove the dependancy for RDP passthrough.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: Cannot connect to VPN on R8500 using OpenVPN
Welcome to the community, @DOTCOM79
Do you have the latest firmware installed on the router?
Did you try to factory reset the router?
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 515 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
