- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot connect to router after firmware update and factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
I installed the newest firmware R8000P-V1.4.1.24_1.2.2.0 and reset the router to factory settings. Now it is not possible to login by Wifi. I can login by ethernet and get the message that i have Wifi (see attachment). The wifi led on the router is on but i don't have Wifi from the router.On the screen from Netgear Genie the Wifi part is orange coloured (see attachment).
As i aim Dutch and 75 years old i hope that you can understand my Englisch and help my to solve this problem.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only one I have used is an Asus rt-ac86u. Ran well for me with RMerlin firmware.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot connect to router after firmware update and factory reset
Hello Tieper,
I cannot solve your issue but want to let you know your English is just fine. I easily understood your router issue as you wrote it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you did the reset you put the router back to where is was when you bought it, default. That means the wireless is whatever is printed on the bottom of the router right now, unless you have logged in to the router via the Ethernet connection and configured it. It sounds like you can login, but have you done a configuration of the router, same steps as new.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your reply. I logged in via ethernet connection and did the same steps as new. As you can see in the attachment i should have wireless connection with the internet. I tried my old firmware version to but with the same results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When i start up the router after the factory reset there is no wireless at all. The wireless what is printed on the bottum of the router should be there but is not. The wifi led on top of the router is on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a newer fw update for R8000P version 1.4.1.30_1.2.26 on NG support website. This should be a good one to update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I already installed the new firmware but still have the same problem. (I expected a reaction from a Netgear moderator).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I aim very sorry that nobody can help me so far and i don't know what to de now. Is there nobody from netgear who can tell me what to do now please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately Netgear does not monitor everything on this site.
If you install new firmware the process requires resetting the router and doing a new configure. Do not use a backup config if you have one, must do configure all over again.
Netgear really needs to address this issue, but so far no. Only other option is to call support and depending on how old the router is there might be a charge. Personal opinion, throw in trash bin and buy router from another vendor such as Linksys or Asus.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you Bill and i think that i'll fololow your opinion. Maybe Asus has a router with the possiblitys as the Netgear? Like OpenVPN server? Do you have a suggestion?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you all (except Netgear) for your reactions and i have to find another router.
