Reply
Cant Forward Port 53
jalalinator
Guide
Ive tried everything, Ive disabled UPNP, Ive disabled media share, I have all 7 other xbox one ports forwarded and my xbox is in a dhcp assigned static ip. when i try to assign udp/tcp port 53 it says Port conflict with other service. but i dont have it assigned anywhere else... im so confused? been on hold with netgear for 60 minutes.
Message 1 of 3
Re: Cant Forward Port 53
Without knowing anything about your environment, run netstat -a from a command prompt and tell us if port xxx.xxx.xxx.:53 TCP/UDP shows as listening anywhere. It's likely the router, which may need a hard reset, but humor us and let us know if you have anything running that is trying to use this port.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 3
jmizoguchi
Virtuoso
53 is used for DNS
https://www.grc.com/port_53.htm
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2317 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
