Reply
Initiate
Cant register product (X4S R7800 - AC2600) WiFi router)
Hello!
I´ve tried to register my new router (Nighthawk X4S R7800 - AC2600), but get a "This Serial number has already been registered in our system". It means I cannot even use ReadyShare at the moment!
It is very important that this router is correctly registered, as it belongs to me.
The serial number ends in *********01C3
It would be nice if someone from Netgear, or anyone could solve this for me.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Accepted Solutions
Re: Cant register product (X4S R7800 - AC2600) WiFi router)
This happens all the time, especially brand new stuff that from Amazon.
Try this:
NETGEAR Product Registration FAQ | Answer | NETGEAR Support
If you are lucky, @Blanca_O, @Christian_R, @ChristineT or @DexterJB will step in.
They may ask you to send them a serial number and the email address you have registered with MyNetgear.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
All Replies
Guru
If you bought it new, I'd exchange it.
You might have gotten a returned product or refurbished product.
CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP
Message 2 of 4
Try this:
Just another user.
Message 3 of 4
Initiate
I can confirm that NetGear Support was able to solve this issue via e-mail. Many thanks NetGear!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 132 views
  • 2 kudos
  • 3 in conversation
Announcements
